Broken HP 500 Crank
160 hrs on hp500 with whipple, same thing, ran, horrific noise, when I went through the engine the pistons showed signs of detonation so I figured that was the culprit
She's a strong running 540 now, in my Pantera which needs a good home
![Drink](/forums/images/smilies/drink.gif)
![Wink](/forums/images/icons/icon12.gif)
Tyler:
Lets face it, GM cranks ain't no perfect parts. I suspect with mass manufacturing and the "bean counters" involved its easier to slip a few through.
Sounds like its going to be a nice nrew motor job for you.
Regards,
Ray @ Raylar
Regards,
Ray @ Raylar
[QUOTE=mrhorsepower1;2085194]I have seen them break like that in a Drag Race app. The crank had approx. 2000 passes and the engine was making about 875 HP. Broke in the same area. Never seen it in a low horsepower engine though. Ouch! Looks like it's time for a 4.250 stroke !
B-MAX REPAIR
I Broak One In The Same Spot, Same Motor. Didn't Loose Block. New Bearing Cap And Line Bore And It Was Fine. I Have A 500 Crank If You Need One.
Ron Bender 216-390-1330
