2000 HP500 Carb Motors
I have almost 300 hours and someone recommending having the carbs rebuilt. One engine doesnt start as well as the other when they are warm. That same engine also idles a bit lower than the other.
Any suggestions??
Any suggestions??
If you have not done the valve train maintaince it is way past due. Talk to someone knowledgeable about the need to replace your lifters. If the lifters are the style using the "tie strap" they must be replaced. I did not do mine soon enough, tie strap breaks, lifter turns in it's bore, grinds up cam, breaks apart, metal all thru engine. $$$$$$
Simply look at the cold engine to see if the choke is closed then look when warm and running to see if the chokes are fully opened. Probably time to replace the power valves.
My carb HP500 have 450 hrs no rebuilds yet.
Fresh valve springs are good for 200-400 RPMS
