No Fire/no Spark Thunderbolt
Happened to me at the river last week. Allothesuddn' DEAD! 10 miles from anywhere. Plugged in my spare module and away we went. Thank God I allways carry a spare! Most likely, it's the module. Attaches to drivers side riser with three small bolts and plastic spacers to mount it with 4 or five wires to it . It is a trangular mount.
Just one engine wont work. if i hook up a test light to the coil on the neg and the positive on the coil i get nothing. if i ground my light to the block i can touch either the pos or neg on my coil and the light lights????? that doesnt make sense... this is all with the key on.
I re -up my first thought. Its the module, plug a new one in and play.....
Hmmmm, i will try module first, cause its the easiest, then the coil. after i check all the grounds. I will let you know. I appreciate the help!!
I think my problem has nothing to do with the ignition system. I have 2 volt power in weird places. They have electric fuel pumps on this boat. They pulled power from the purple wire that goes to the main wiring harness for the pump. some times i have no voltage at the coil on the positive side and sometimes i have 12v. If a boat has electric fuel pumps where should the power be taken from?
