Steering actuator
"Unregistered Gun"
Can anyone help me troubleshoot my steering actuator or steering cable? I have play in my steering, if you center the drive and put your hand at 12 o'clock position you can go to about 10 1/2 to 1 1/2 position with no movement, the actuator never moves the tiller arm on the gimbal ring. Also you can barely move the outdrive and the steering wheel will move with it??? Its on a 2003 496ho and Bravo 1x.
If the tiller arm does not move you have play in the steering wheel or maybe the rack and pinion at the helm. More common is to have play between the tiller arm and the gimbal ring. Some times it helps to tighten the ubolt on the gimbal ring. Should be done every year according to merc. It is a lousy design. Go full hydraulic.
"Unregistered Gun"
Its a 25', I tightened the u-bolt the other day to make sure and it was already tight the tiller arm does not move that was the first thing I checked. I just dont know a good way to troubleshoot the cable or actuator?
you dont state wether this happens with the engine is runing or is not running. What happens to the steering wheel when you turn the drive from outside the boat ? Do you still have the same amount of play. Look at the drag link (it connects the tiller arm to the end of the steering cable) when you turn the wheel dose the movement corospond to the amount of turning of the wheel. Have someone turn the wheel and check inside the boat at the transom any play there?
"Unregistered Gun"
check to see if your steering wheel has screws that hold it on other than the nut in the center! I ran into this situation before somebody forgot to put the screws that hold the wheel onto the hub! It had alot of play.
