Dielectric grease VS water proof grease
NAPA has "waterproof" grease, it is red in color. Pennzoil makes a white grease;
http://www.pzlqs.com/Tech/Pdsheet/Do...eGrease705.PDF
Spray Lithium grease is usually used for corrosion protection.
You need to be very careful if using any actual "Grease" on low voltage electrical connections. Many types of waterproof "grease" contain enough mineral materials to conduct electricity. 5 volt signal circuits don't like losing any voltage across circuits( ie inside connectors ) so only a high quality dielectric compound should be used.
SORE MEMBER
1 Post
Originally Posted by [email protected]
Ive always used dielectric on all concealed connections new or used never had any problems. You shouldnt need waterproof grease there hopefully its not getting wet. Just get out the KY and use that!
Rough Seas Lie Ahead
Okay so what is a good off-the-shelf dielectric grease brand that may come in a spray can or something besides those little squeeze tubes? I'm looking for quantity & good shelf-life in my shed when not in use.
Available in cans or 8 oz tubes from MSC
