oil fittings
oil fittings
I finally got my oil lines made. I got a few straight 1/2" NPT X 5/8" flare fittings. I need a few 45* or 90* ones. These are the ones I got. The silver one is a 45*, but the hole looks much smaller on the NPT side. The 90* ones are huge compared to the 45* ones. I know that the 45* should be better for flow, but does the openess of the 90* make up for the extra bend?
(Can't find the d@mn attachment button, let me try to reply)
well that didn't work...
where's the stupid attachment button?
oh. Looks like my membership expired... let me fix that.
I hate the winter!!
Those fittings lookto be too restrictive. You should stay away from 90* pipe bends. When you need to make a bend, you should look into using smooth bend AN fittings.
absolutely. 90* nipples are very restrictive. use a straight nipple with a radiused hose end, so you dont interupt flow. also the lines should be -10. unless you have big power then use -12.
