454 Mag Mpi 540 Easy Hours, Blower Time??? >
Old 05-12-2007, 10:52 AM
Default 454 Mag Mpi 540 Easy Hours, Blower Time???
Hello Guys and Gals,
Weather is great up here in Toronto! Been out a couple of times already! I have a '00 454 MAG MPI bone stock which I have owned since new. Always idled to operating temp, regular oil changes, and alot of easy cruising hours. Still runs the exact same as brand new, doesn't burn any oil.
I just ran into an unbelievable deal on a brand new paxton supercharger... Do I bolt it on and wait for some part to break, or what should be done to prep this motor. Also anyone in Ontario have someone to recommend to do the work?
Thanks!
H2X BOSS is offline
Old 05-12-2007, 11:41 AM
PatriYacht's Avatar
If you only wanted to run 3-4 pounds of boost, you could probably get away with just reprograming the ecu. Considering the hours on the engine, even at this low boost, I would also have the heads rebuilt and better head gaskets installed. Any more boost than that, things get complicated fast. You will need a better fuel system, better oiling and better cooling. If you are not a good wrench, a pro built engine and a re-rig is in order. $$$$... Good luck
PatriYacht is offline
Old 05-13-2007, 12:58 PM
Lakeside Restorations.com
Commercial Member
LAKESIDE RESTORATIONS's Avatar
@ 540 hours to add a blower without a refresh is not usually a wise thing to do... Also I am not sure how you would plan on marinizing a paxton set up.. Even if you did & the hours were low, you would probably be better off paying the difference & go with a whipple or Procharger. It would be easier & checper in the long run.. Plus it is right for the application.... Just my opinion.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
mg503
Baja
14
04-03-2013 05:50 PM
mittens
6
06-06-2008 05:54 PM
cliff3466
1
03-09-2008 09:10 AM
MC-BOYS
7
07-11-2006 03:15 PM
Elite Marine
Pantera
0
08-18-2004 08:48 AM
Quick Reply: 454 Mag Mpi 540 Easy Hours, Blower Time???
