Aeromotive 1000 stoped working
I have a procharger set up and have just re-built after a melt-down. I am very sensitive to adequate fuel pressure although my melt down was due to smaller stock injectors. I just got the re-built 7.4 back in the boat and was in the process of setting initial timing and the motor quit @ 1800 RPM. I attempted a re-start and noticed the fuel pump was not setting initial pressure like it always does. I checked the power source all the way through the relay to the pump ALL OK. Hot wired direct to the pump no-go. I took the pump out and bench tested it GO. Put it back and got the timing done. I called Pro-Charger, where I bought the pump and they accused me of twisting the terminals and breaking the wire inside in the process and then they said call Aeromotive HUMM. Aeromotive said that if I had twisted the post during install then it would not repair itself as it did. I am paranoid and am not sure the pump is winding up as it did during initial priming. Pressure was good at low RPM which I recognize is no test. Anybody have similar problems with Aeromotive 1000
shake the wires around to see if they infact do "short" or "ground" out. If that doesn't work... verify you have the proper voltage. If it isn't 12 volts.. it could be a problem. Did you bench test with a fresh charged battery and possibly have an undercharged battery in the boat? Did you happen to check and verify you have an open circuit straight to the pump? Just wondering because Aeromotive does have voltage control modules.
Sent 3 back for warranty now use it for a back up. Now only use Weldon fuel pumps never have any issues. 1st one fuel poored through the + and - terminals 2nd one check ball failure 3rd fuel pressure went crazy fluctuating from 30-60lbs. under load. They have always warrantied them its just scary having a fuel issue with the money we poor into these motors. Not worth the risk to me Weldon is the way to go for EFI.
Registered User
bench test it with wires attached and see if you can duplicate the problem, by moving the terminals around. If you can't, test it in the boat the same way. Its pretty much just a little electric motor that either works or doesn't.
I have twisted the wires off inside , I wish they would make a stop so it want turn. I didnt twist it that far.
I had the old style that took dumps, even bought a spare that took a dump.Whipple started out with areo and went to SX then went back to areo, dont know why though, supply or quality?
I bet its in the wiring not the pump unless it got hot and seised
I have the same setup. I also melted a motor. My aero pump acted like it was working but couldn't supply the volume on top end. I replaced it with a new one and everything is good now.
