More Pro Charger tuning Progress and AFR RAtios >
Old 04-25-2008, 09:38 AM
  #101
Good talking to you on the phone. Give Tyler Crockett a call for that SX regulator and see if that helps your issues.
Griswald is offline
Old 04-25-2008, 09:41 AM
  #102
Thanks for the call Griswald. I will try and get a hold of him today. I'll let you know.
Warlock28SXT is offline
Old 05-05-2008, 08:10 AM
  #103
What plugs are you using in these engines.
baja27 is offline
Old 05-05-2008, 10:00 AM
  #104
I use MR43T
Griswald is offline
Old 05-05-2008, 10:12 AM
  #105
I tried the NGK 2756 with no change and now after reading on OSO I bought NGK 4554. I don't know how they work due to a sea water pump failure. Anyway I should be able to get out today, baring any other little things stopping me, to try these plugs and pull some fuel pressure out of the motor per articfriends suggestion and others.
Old 05-06-2008, 07:45 AM
  #106
MR42T or equivalent.
kennyo is offline
later
3
08-03-2008 02:00 PM
Fenderjack
Wanted
2
07-20-2008 06:49 PM
ghittner
0
07-19-2007 10:04 AM
dyno
10
01-17-2004 06:29 PM
Biggus
3
10-13-2002 07:52 PM
Quick Reply: More Pro Charger tuning Progress and AFR RAtios
