More Pro Charger tuning Progress and AFR RAtios
#51
Mine was tuned in the boat. I needed to run that much base to get enough up top under boost. I'm golden.
#52
Does your fuel pressure rise and stay constant throughout the run?
Maybe your fuel plumbing is the issue. I run my main fuel line to an SX regulator then take the return from that to the FMU. The output of the FMU returns back to a T fitting at the inlet of the fuel pump.
#53
the anti siphon valves are in the fitting that your fuel line hooks to at the tank it might be a elbow or maybe straight. pull the hose off and unscrew the fitting from the tank and see if there is a check valve in it . if so the hole is only a 1/4 inch and has to lift the ball off the seat as well.
#54
So you have ECM tuning capabilities?
You have the mechanical ability to swap injectors?
Why in the world would you be still running a FMU? This is not 1985. 14.5:1afr that motor is a ticking time bomb. Also at 11:1 at low rpm and no boost you are just putting fuel into the crank case. Wow!
#55
What color is OK ? how much boost are you seeing? What throttle body are you running?
#56
Thats whats fundimentaly wrong with procharger. Tuning the AFR by running the engine to different rpms and then shuting off and looking at the plugs. Thats seems so rediculess.
#57
Using the old ati regulator my plugs looked perfect but I was adding a QT. of gas to the Crankcase everytime I went out.
I think it normally takes 2-3 engines to figure out a procharger, Just ask me Jerry and Smitty!
#58
Sometimes you have to work with what's available. Add a wideband 02 sensor and run some data logs, add an aftermarket ECU, adjust whatever you want. Either way you'll probably want to varify AFRs and timing with plug readings.
#59
Jerry
I just pulled the fuel lines off at the tank. no anti siphon valves.
Kennyo
This is my second motor. The first one died before I had a chance to dig into this. I'd love to get this resolved 80 MPH is just not cutting it. My last boat ran 100+ w/an OB.
Thanks again to all for the input
