More Pro Charger tuning Progress and AFR RAtios
#81
I spoke to Mark at Precision Marine today. He told me they do not remove retard timing under boost. Mark also mentioned running a projected tip plug( bought and installed stock gap .040) Thank you Mark, idle and mid are better than before. I also got a list of RPMS that can be mapped. took the readings will send to PM to compare my setup vs real world.
I have replaced cap rotor and plugs, not the coil or wires stock coil mallory 8mm wires. While out today I did notice that @ 3200 RPM the AFR would shoot to 9.5. AS far as air goes, I removed the entire engine hatch, if thats not enough air I'm in more trouble, no real change, another dead end. I will see if I can get my hands on a scan tool Tuesday per Mark @ PM to see if I have something else failing. I went up in fuel press under boost to verify I was not nocking and the ECM was retarding timing making the motor real rich. The motor sounded more heathy but 3200RPM AFR still 9.5. from about 12.5 at 3000 RPM. I ran out of time to go the other was with pressure. Will continue Tuesday with scan tool and fuel adjustment more lean and see what happens. Ever feel like this is what your boat is winning?
Cam specs Howards cam .577 / 280 intake .579 / 292 exhaust with 112* lobe sep.
#83
I have done it several times, won't hurt a thing.... (just don't let a misc, grocery bag get loose in the engine compartment.... it MIGHT end up in the innercooler)
#85
#86
#88
I have considered going to a Mefi3, but at this point I wish to make it run as good as it can as is. Rain for the next few days we will see what transpires when the weather breaks.
