Oil type and level for fuel pump housing
Charter Member #139 /Moderator/Platinum Member
I have HP500 motors with the belt drive fuel pump what type of oil should be in the housing and how much?
I saw there is a side plug in it and am thinking you just fill to that level.
Kept the Bullet and the condo and joined the cig 20 restoration club.
Were doomed!
yep...there should be two plugs...one to fill(top) and one to drain(bottom)
fill w/90w oil and good to go
-Wally
-Wally
Mine only had one plug as well. I could take out most of the bolts on the seapump bracket and tilt it enough to get out 95%of the lube. I've always used Merc Hi perf gear lube aka drive lube.
mine was the same one hole in the side of resevoir
Removed fuel pump was rebuilding water pump also so just removed whole assembly and then emptied it out and then used royal purple synthetic
ratman
04-17-2006 03:11 PM
Nordicflame
4
03-04-2004 10:21 AM
