Compression ratio with 049 heads
More info needed? The heads are worked and have the larger valves (2.19/1.88) so those flow numbers are off a little.
I've already got the parts so I'm sticking with it... the real question should be if 9.4 is a tad too high should I use a thicker head gasket to bring it down a few tenths?
The boat will live on a trailer so I should have regular access to 91 octane.
I'd like stay with 91.
The answers I'm getting from the machine shop and valve train guys is a reserved, "I wouldn't go any higher than that". The guys at strokermotor.com said I shouldn't go to 9.4... they wanted me to stick the 3cc flat top and run 87 octane (or get aluminum heads).
I would not with iron heads.
If you do be conservative with the timing.
You need to ask yourself is it worth the chance?
I can play with timing at the dyno... couple degrees on the safe side then. I can also choose a little more gasket volume when I know the exact deck height. I can probably get it down to 9.1. We also have 93 octane here, but no telling how much longer it will be at the pumps.
Here's a damn good article which really helped me understand compression ratio.
http://www.carcraft.com/techarticles...ression_ratio/
I've never seen it put in as simple terms.
"Compression ratio is the relationship of cylinder volume (or displacement) with the piston at BDC to cylinder volume with the piston at TDC. If the volume of the cylinder with the piston at BDC is 10 times greater than the volume of the combustion area with the piston at TDC, then 10 units of volume get squeezed into 1 unit of space, and the compression ratio is 10.0:1"
That is until I used this calculator on the KB site. I understand how cam timing effects CR (intake valve not closed at exactly BDC), what I don't understand is how a rod length can effect stroke!? In my mind a 4.25" stroke is a 4.25" stroke... even if you put a 10 foot rod on it the stroke will still be exactly 4.25". I may have to call KB to get this one explained.
JackHammer,
What H.P. are you looking for?
and,
Where do you want the torque range?
What cubic inch motors are you starting with? 454's?
IMHO, You may want to mirror the cam specs for the HP500 carbed motor. Also, was a head flowed to your intake (dual/single plane?) to decide on cam choice?
I've made a few mistakes in the past and don't mind sharing what not to do!
and,
