Water pressure guage question
So where do you guys put the hose for your water pressure guages? In the block or intake? Is there any difference?
Reason I ask is, I just built a new motor and for the first time I hooked up a guage. I used the 3/8" port right beside the T-stat housing. I'm pegging my 30psi guage at just over 3500 rpm. Engine is 502 mag efi with AFR heads, holley intake, genVI block, hardin marine oil cooler, fuel cooler, and brand new merc water pump. I'm also running a circ pump.
Thanks,
Frank
Thanks,
Frank
