high pressure fuel pump
i have a 1995 baja 272 454 efi with a bad high pressure fuel pump does any one know of a aftermarket or a gm pump that will work mercurser pump is over 500.00 thanks
Is it the pump that looks kinda like a filter..long and round..mounts under the fuel cooler..if so, those are nla and replaced by part# 861156a02..which sells for $300...BUT, if you look on ebay you may find your original pump part# 861156a1 for around $150...hope this helps!
