Oil running too hot
What is the oil pressure in the engine that runs hot BBB vs the one that does not? Something I have noticed as I have battle oil temp problems for years, how the engine is built makes a large difference in oil temps. Clearances wise that is. That's why I ask about oil pressure. If your pressure is high you may get an oil temp benefit by lowering the viscosity of the motor oil you use.
Also, I would try lowering the oil level by a couple quarts as a test. 16 qt gives you lots of room to lower the level. I'd try 10 just to see if it changes temps dramatically.
