496 IAC Output Fault Mystery...Solved???? >
Old 06-27-2007, 08:38 AM
OSO Moderator
BillR's Avatar
Maybe Tom @ Norfolk marine can get your ECM re-programmed and updated if there is a new version of the program. It's worth a visit. . . . .
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 06-27-2007, 10:56 AM
The problem follows the ECU? You need a wiring schematic of the ECU pins to find the input for IAC. SOMEBODY on OSO must have it, if nothing else give you the location to visually inspect. It's possible that connector pin has a fault internal to the ECU.
handfulz28 is offline
Old 06-27-2007, 11:20 AM
Dave_N's Avatar
I know you have a service manual on the way, but maybe this will help in the meantime.
Attached Thumbnails 496 IAC Output Fault Mystery...Solved????-pcm01.jpg   496 IAC Output Fault Mystery...Solved????-iac001.jpg
Dave_N is offline
Old 06-27-2007, 01:47 PM
Rough Seas Lie Ahead
Reckless32's Avatar
Thanks Dave,
I have visually inspected the pins both on the ECM, and the connectors themselves looking for a pushed/bent pin and or female connector, and can follow the IAC wires thru the harness to the center connector on the ECM, but all looks in good shape?
Again the IAC seems to be working, just slow to reduce from 99.9% count on the tool setting off the alarm. I can feel the varying suction thru the hose from the TPS to the IAC when I put my thumb over it and remove it several times. Also I noticed the % count on the tool seems to be a little higher on average when at idle than the other ECM motor which will show almost nothing. The other when I pump the throttle and back will spike up in % but come down much quicker?
Reckless32 is offline
evaluex
3
07-06-2008 05:09 PM
45auto
0
05-26-2008 09:25 PM
fountain27ho496
7
09-01-2007 06:39 AM
fountain27ho496
1
06-12-2003 01:08 PM
Chris288
04-08-2003 06:41 PM
Quick Reply: 496 IAC Output Fault Mystery...Solved????
