Procharger, oil pressure and water temp?????
#31
I am almost consisdering going without an oil cooler on the new set up, but I may have to break down and put in a thermo
#32
I didn't have an oil temp guage on the last set up. I was running with no thermo and then a 120 deg. thermo with 2x 1/4" holes and either way the water temp almost never even registered and the oil pressure was throught the roof.
If you do not have any gasket issues. Getting it to
run above 212 will clean that milkshake right up.
I would run mechanical oil pressure.
Run a Electric oil temp.
They make dual function gauges if ya running out of room.
You can never have enough gauges.
#33
I was just looking at those canton thermostats....how did you plumb it into your system?
#34
I've got a new Mocal sandwich type t-stat that I didn't use. I already deburred it and opened it up to max flow. I'll take $75 and ship it to you. I think they are the easiest to use and cost around $90.
#35
I saw those, but I beleive they are set to 180 deg. I'm thinking I want to go with something like the canton that is set to 215 deg. I would certainly like to save the money though, this is getting rough.
#36
I think you can change the pill in it to 212*. Check and if you can i'll make you a deal.
#37
I may take you up on that.... can you tell me the part number on it? I see thay make 180* and 200*... I can't find where you can by a seperate vale though. Also curious what fittings are on it.
#39
The KE style oil stat is easy to plumb and available in 180 degree and 212 degree.
Also I have a nice M-1 with AW324 intercooler for sale complete for a 7.4, 454 or 502 MAG EFI set up.
Kirk
Kirk
#40
I already have the procharger setup, thanks though.... who makes KE style thermo?
