How do you know if octane stated on pump is accurate?
How do you know if when purchasing 93 from a station on land if it is really 93? With the price of fuel I can see some stations wanting to increase profits a bit and mixing in some lower octane. Perhaps the driver could make a mistake? I only purchase from name brand stations but I am curious how often the product may get mixed into the wrong tanks. I assume that doing that intentionally would be against the law but s**t happens.
Is there a quick test kit?
Any thoughts on the likelihood of this happening? For some of us running boost or high compression this could be a fatal event. How many engines have melted down due to getting the wrong fuel?
Tim T.
Tim T.
I've had fuel checked by the county Weights and Measures a couple of times when my car started pinging more than I expected. Each time the fuel sample they took met the octane specs.
Michael
Michael
Tim T.
Tim T.
In Mi the bureau of wegts and measures is more concerned about gas staions shorting people than giving the wrong octane. In a article in the detroit freepress last year they said 20% of gas stations tested had LOWER octane then what they claimed. I had a snowmobile that required 92 octane or better,ran it 80 miles with no problems,bought 93 octane at a small UP gas station,it detonated itself apart 7 miles later so,yes,it is VERY possible to get lower octane gas then what the pump claims. My boat needs 92 plus octane,I buy 80% of my gas from a local station that I trust (they also DON"T sell ethanol),when I buy gas out of town I often buy 10 or 20 gallons of race gas if possible to ensure I have enough octane,Smitty
Whats up Smitty? You going to Hardy soon??
![Post](/forums/images/icons/icon1.gif)
Doctor up your fuel with 114 octane Toluene available at any hardware store for about $9 Gal. Avoid Xylene or otherwise called Xylol its 116 octane and will destroy fuel pumps carbs lines and any other parts. It is actually a rubber solvent used in the industry. Be safe instead of sorry ! Avoid Methanol and these fuels like VP unless you plan to burn up everything in your tank, or drain it. My buddy could not get out of his canal because he used the race fuel and had 3 gallons of water in his tank. Pure BS ! BBB
mcprodesign
Fountain
16
05-13-2008 03:46 PM
ENFORCER24
Insurance and Finance
42
12-05-2007 11:34 PM
