Finally got my motor back together & DYNOED!!!
#41
Dave, I thought My smallest pulley was going to make 1025-1050 and I could run my 4.00 pulley and make about the same power I used to and run that set-up most of the time to keep the drive together but the bigger cam really raised the power (I made 1037 with my biggest pulley) so I think I'm going to have to get a 4.25 pulley to tame it down for long trips and vacations. I do have a spare max worx drive but I don't want to break one every weekend.I might get a B-max and sell both my max worx drives,the spare only has a few hours on it,Smitty
#46
I had the option of going as far as 4.630 on my bore but chose to stay at 4.500,I would rather have stabil cylinder walls with less distortion and run more boost then go for a few more cubes. My blower is past its rating already so if motor was signifigantly bigger It would have probably made the same amount of power and flattened out early without investing in the next size blower or the intake runner size may have choked it off too,Smitty
#47
I have 14 hours on the motor now,boat runs 76-78 mph gps N/A turning labbed 26 pitch merc 5500 rpms. Boat ran 97 mph gps today turning 32 labbed around 6100 with the medium pulleys that made 1057 on the dyno (hard to watch the tach much). I have been thru msd hell with the msd marine boxes,the third new one showed up friday,I have bought a msd ignition tester,the newest box was DOA,after tapping on it and wiggling the wiring harness trying to run it with the tester I could get it to spark intermittintly and it would short out the tester after 5 or 10 seconds,calling msd/jegs AGAIN in the morning- DON't BUY A 6560 ml-2 box! So I was testing today AGAIN running the stock ignition. Boat is real spooky running by myself (which I rarely do),saw 94-95 gps on short burst, my son and his friend showed up at the ramp and I was able to use them to balance out the boat and saw 97 mph,Smitty
#49
Charter Member #655
smitty you aint right!!!!I hope your wearing a life line jacket and a helmet!!!!
If your boat has a sail do you ride a horse to the ramp?
