Best sounding mufflers
I may need to replace my CMI sound elimination mufflers but I do not want anything that is much louder.
Any suggestions for a more deep sounding mufflers that work with an HP525? The CMI's are OK sounding, mine melted from an overheating issue...see were the track slides.
They are stuck in a slightly open mode and may be too loud at idle and then may rob some power at WOT?
I need to pull the trigger shortly.
Thanks,
Jamal
Thanks,
Jamal
Jamal
Those must be the original CMI Mufflers. The new ones are all SS and therefore do not have this issue.
If we can get you a new pair, let me know. We'll give you a very nice deal for upgrading.
Kirk
Kirk
Thanks,
Jamal
Thanks,
Jamal
Bawana
Jamal, I would not run that 525 if the muffler will not open. At WOT you will have too much back pressure. Get them rebuilt, or call Kirk and get a new updated version if CMI can't do anything for you.
Bawana
Bawana
Thanks,
Jamal
Thanks,
Jamal
Captains Call system would be nice....I think that would be quite involved to retro fit it, wouldn't it?
I am debating if I should get another clamp on style muffler, or since I have most of the exhaust/muffler already appart to go ahead and install a transom mount unit?
Besides looks, is there an advantage to have a transom mount muffler?
Jamal
Jamal
Jamal
Jamal
Brian41,
What is involved to install the Captains Call to my set up? How do you route the lower exhaust to/through the transom/outdrive?
How much is 50% off?
Thanks,
Jamal
Thanks,
Jamal
