Just rebuilt motor... runs hot, what now? >
Old 07-24-2007, 12:41 AM
mcollinstn's Avatar
the holes aren't for bypass. The holes are for air pocket purge. A good sealing auto stat with no holes can trap an air pocket around the sensing portion of the stat and keep it from opening properly. It can then go thru an overtemp/open/cool/close/overtemp/open cycle. Not saying this is his problem but you should run a stat with a small bleed hole (1/16 will work).
mcollinstn is offline
Old 07-24-2007, 07:10 AM
SB
Received 3,331 Likes on 1,493 Posts
I've seen handfuls of people install t-stat + components in wrong order or use wrong parts/gaskets.
Click here : http://www.mercruiserparts.com/Show_...COOLING+SYSTEM
And note order of parts and part #'s - especially gasket up at top. Look at #5,6,7, and 8.
Also, take a look at water hose from drive to transom assembly. Over time these can get real soft and kink, especially with drive in up position. Easier to check while on trailer. This is in addition to info given above from others.
Yes, sometimes cooling issues on the hose disappear in the water. Some water supplies/hoses don't provide enough volume.
SB is offline
Old 07-24-2007, 09:05 AM
cuda's Avatar
I've never seen an Alpha yet that didn't steam from one bank after a hard run. I can't remeber which side though. Those were Gen1's, they may have corrected it on the Gen 2's. Personally, I never thought an Alpha drive pumps enough water anyway, especially with the warm water we run in here in Florida. If I ever do another Alpha set up, I'll put a transom mount water pick up, and a seawater pump on the engine.
cuda is offline
cloudmaster_321
12
10-13-2008 02:00 PM
totalrex
6
09-26-2007 12:18 PM
totalrex
8
08-06-2007 04:08 PM
robclark
2
08-02-2006 07:16 PM
Waveline24
32
10-28-2002 06:02 PM
Quick Reply: Just rebuilt motor... runs hot, what now?
