question on a 486ho problem >
Old 07-22-2007, 07:45 PM
lulu's Avatar
Default question on a 486ho problem
hello guy's i have a 2004 baja ol 25 with a 496ho. the beeper sound every 1 minut or so 2 close bip i really don't know what it is . my gauges and fluid level are ok?? anybody know??
lulu is offline
Old 07-23-2007, 01:22 PM
Mine turned out to be the water pressure sensor on bottom of seawater pump.
bcolmsted is offline
Old 07-23-2007, 02:31 PM
Bill 3's Avatar
Probably the easiest and quickest way it to put it on a computer, there will be a trouble code.
Otherwise, what is the last thing that was changed/done on or around your engine? For instance if the impeller was just changed, I would look at the sea pump pressure sender for damage.
Bill 3 is offline
Old 07-24-2007, 03:06 PM
your rite, the alarms started shortly after impeller went to pieces..the laptop showed it reporting 40 lbs of pressure and its only supposed to be about 6lbs.
$99.95 plus labor
J.B. Marshall
06-16-2015 01:40 AM
rssteiny
10
10-14-2007 08:00 AM
J.B. Marshall
3
08-11-2006 12:03 PM
J.B. Marshall
1
06-12-2006 08:45 PM
Quick Reply: question on a 486ho problem
