Anybody running wet exhaust on a carbed HP500?
I have been reading a little bit (dangerous, I know) and see that reversion is a concern with these engines.
The engines in my boat are equipped with stainless marine dry exhausts now, but I would like to put a wet exhaust on simply for noise reduction.
What do you all think?
Thanks for any info....
Greg
Greg
The earlier HP500's had a regular "low" riser on the Gill's that some had water reversion issues with. Merc then went to a taller riser set-up that pretty much ended any issues.
Here's a pic of the taller one's on HP500:
Mine has the low risers, and the outboard risers have a reversion dam in them. The inner ones do not.
The dry pipes look to be dry only because the water ejection flutes are welded shut. Seems like a guy could simply open those up and have a wet exhaust.
Greg
Greg
