502 intake gasket question - urgent help please!
I am ready to reinstall my intake on my GEN VI 502 with Carb and noticed that the new Merc intake gaskets do not have a cutout for the exhaust crossover port.
Now, I have a carb and the choke is not electric, so how should I open the port in the gasket? Can it be as simple as using a razor knife to cut away the gasket covering the port, or does it need to have something metallic there because of high heat?
Thanks in advance -
Thanks in advance -
just install the gasket as it is (no crossover passage) I would also wire the choke in the full open position or remove it completely as its really not needed. It will most likely run better without the extra heat.
