Pulling my hair out, engine misses at 4K... >
Old 09-12-2007, 12:28 PM
  #31
Taz, do take a look at adding a diode to the pull of the solenoid. You can get voltage spikes when the field collapses that your alternator or stereo equipment may not like. Ask pop about that. All I know about it what I read but it does seem possible.
BadDog is offline
Old 09-17-2007, 02:24 PM
  #32
O'l Dad said the amount of amps generated from a relay coil of this size is minimal. You plan to put the relay between the key and the ignition coil right? The starter solenoid does not need the relay.
I put my relay in Sat. next to the ignition coil and it took care of my high end breakup.
TAZMAN is offline
Old 06-13-2011, 04:46 PM
  #33
Stumbled on BadDog's thread from 3+ years ago. It is somewhat applicable to my ignition problem posted in another thread on here. I do not seem to be getting a "clean" 12V at my coil, after the purple wire has to run its tortuous path back from the ignition switch, lanyard, gauges, etc. The relay sounds like a much cleaner solution to me. My question: I just installed a relay to run the fuel pump, which is in fact triggered from the purple wire on the coil. Couldn't I just tap another power line off of the "big" side of this relay? It would eliminate another component that could possibly fail. A 12 or 10 gauge wire running 2 feet or so from the relay up to the coil would have to be cleaner than the way Merc does it. I can't see the coil robbing enough amperage from the FP circuit to matter.
Any opinions?
Budman II is offline
Old 06-14-2011, 09:19 AM
  #34
Anyone?
gripit
8
08-19-2007 09:25 AM
24degrees
Fiberglass and Paint
10
12-28-2006 02:56 AM
rcarney
7
10-06-2006 07:04 AM
Rage
Nordic
9
10-11-2005 11:56 AM
JGB
40
02-16-2005 10:26 AM
Quick Reply: Pulling my hair out, engine misses at 4K...
