Engine cuts out when I hit a wave ???
#32
Well..... I ran the snot out of my boat this weekend and did not have a single problem. The "cutting-out" is gone. The tach does not flicker.
Here`s what I did before sea-trial :
Replaced kill switch / lanyard with NEW one. Tightened and cleaned all ground cable / wire connections. Cleaned battery cable connections. Inspected all wires going to dash and related components. I found a loose ground wire at tach (for lights). I also found a "suspect" hot wire at ignition switch - I cleaned and tightened it. I may have knocked it loose while I was messing around with the other wires .... ?
Unfortunately, I`m not sure what fixed this problem. I am leaning towards the kill switch. It was the original (15 yrs old) and didn`t look very good.
RiverGirl
08-25-2003 06:27 PM
