Engine Air Intakes >
Engine Air Intakes
Engine Air Intakes
Old 08-31-2007, 03:27 AM
  #31
the Flightmaster
Wild Card 09's Avatar
I like Tomcats theory about seperating the intake air from the ambiente engine compartment air. He´s right that the intake temp that will improve performance is lower than the required temp for the rest of the motor (160 - 200°F).
Arcticfriends experience also highlights a problem that at the intake venturi any type of channel can work like a restrictor, even when it looks like it should do the right job. I´ve seen ideas like running ducting from outside the cockpit, in a high pressure area back to the intake. The problem is that the length of the ducting will already act like a restrictor.
@Smitty Difficult to find a good place to pull in air on the 272, and the engine compartment is tight, too. You don´t want to put a scoop on it, I suppose, because itwould ruin the sleeper character of a 90+ mph 27 footer
But what about fitting spacer blocks between the hinges and the sunpad (which would raise the rear of the pad - it sits really deep on a 272 anyway, maybe it can go up 2") and then adding a filler panel (maybe 3" high) between the front of the sunpad and the lower seatback area. This pad could have slots running across it
(2" x 12" x 3). You could use standard vent grills like the rear ones on the 25.
You would only be raising the sunpad up to be a little over flush, and would increase the space in your engine compartment!
Wild Card 09 is offline
Old 08-31-2007, 07:41 AM
  #32
CNC
CNC's Avatar
Smitty,
On my Baja I have spacers to keep my sundeck cracked about a 1" to allow more air in ...
Randy
CNC is offline
mattd7
Do It Yourself, Boating on a Budget
10
03-31-2008 06:26 PM
fatdaddy
Baja
6
09-10-2007 09:19 PM
FRMULTR
Eliminator
2
01-19-2007 10:34 AM
Buddy OO
22
07-31-2006 05:30 PM
georges
Pantera
2
10-04-2004 10:28 AM
Quick Reply: Engine Air Intakes
