Bulldog / 7.4L TB-V Ignition Experts; Question
I am going to be upgrading an 1996 7.4L Gen 6 carb motor (0F810161)
to a 489 stroker 10:1 CR with new AL heads and all.
I have a take off ignition module 848821 off of a 1996 Bulldog that I would like to use on this build. This is also the same module is used on the HP500 carb motors.
• Is this just a simple module swap? I see that the distributors are slightly different (Bulldog 805185A43 vs 7.4L 805185A36) but all else looks the same.
• Also is this just a simple 20* module and where is the rev limit set?
• I’m assuming that this does retain the timing assist as well, correct?
Any help would be appreciated…
Thanks,
Dave
1996 7.4L GenVI Carb TB-V
http://www.mercruiserparts.com/Show_...CAL+COMPONENTS
1996 Bulldog TB-V
Thanks,
Dave
1996 Bulldog TB-V
