Never seen anything like this. >
Old 09-07-2007, 01:33 PM
  #31
do you have zincs installed? The zincs are nuked first. If the zincs are Ok the current is probably coming from your boat.
If the zincs were nuked too, the faulty wiring was probably from the boats that surrounded you...
VetteLT193 is offline
Old 09-07-2007, 11:01 PM
  #32
THanks guys. (Girls?) I used mild acid and washed it off right of way. I got most of the corrosion off. The boat was checked ..the merchathode system is OK. THe anodes were fried. Pitted and light as a feather. Got new onces. After some research, here is the story... There was and is a problem with the docks, near the reastaurant. I was the closest one to the sourse, My boat got the residual effect of to much current in the water. Lesson learned after 100's of $. Invest in a current/volt meter and stay away from ceartain docks or areas. ( like reastaurants next to the dock)
I have heard, that droping anchor with a small Guage wire attached to it and grounded to the block, will help gounding in bad dock areas. Don't know.. just a thought from some one ..
For now I will avoid Hyatt untill I KNOW THEY FIXED THE PROBLEM.
I will post the current readings once I get it just in case some needs to be aware for the Sarasota Run.
PARADOX is offline
