milkshake oil and holds 15lbs in crankcase
![Angry](/forums/images/icons/icon8.gif)
I have a small water leak, the oil turns to milkshake after about 10 hrs, I removed the oil cooler and pressure tested it ok, and then pressure tested the block, (an old 400) and it held fine, 15 lbs. I listened closely to the engine and it runs fine.
Check the intake manifold gasket and the riser gaskets on the exhaust manifolds.
zimm17
4
05-17-2006 05:24 PM
baronbob
8
05-10-2005 09:23 PM
