retrotek??? anyone know?
Charter Member #601
rdoactive,
I am using the MSII on my 565" motor. Took a bit of a learnig curve but it is working quite nicely. I did modify the driver circuits for the Low Z injectors, to a more reliable setup. The Megasquirt works much better than the Culter system I ran for years!!
Cost is low, but then you have to figure in the hardware that I already had.
D*ck
D*ck
That system has no real advantage over a carb. You are still running a "wet" manifold and not taking advantage of the fuel injectors atomizing cababilities. A multiport setup is the better way to go without question.
Frank
Frank
I don't see it making any more power than a carburator, when used in a boat.
