meltdown
Time to tear it down and replace everything. You can't just replace one piston without tearing the engine down and making sure everything else is ok. If the rest are ok, at a minimum you would need to re-balance the assembly for the new piston. My guess is that there will be more damage than what you see. On top of that, if one piston went, the others are not far behind. Sounds like a detonation problem which means that the stock pistons just can't handle the cylinder pressure due to age or material, or you may not have enough fuel in the system to keep up with the added demand of the supercharger. If you're going to run the supercharger, you need to build the engine to handle it and make sure the fuel system will be more than adequate.
what exactly happened to the piston?? Did it go due to detonation?? If so you need more fuel.
detonation,or lean out,lost head gasket too,it all went fast,did not hear a thing,just lost power.look like im going all stock and no procharger.going to get a remanufacturd 496 from merc.oh well it was fun for 60hrs
