Cast aluminum BBC gen V r VI oil pan?
Why do you want aluminum? There is no point in a marine application.
As was said above, proper control of the oil in the pan, the windage tray and whatnot, is important. But there's not enough airflow around an oil pan in the boat to make it an effective cooler, especially with the loads boat engines run. And nobody is going to see the bling bling on the bottom of the engine.
As for steel pans, I used to have a 31' Sonic I brought here from Miami. I pulled the engines after a year or so and freshend everything. I had to replace the oil pans cause they rusted through at the flanges. I can only assume do to the salt in the air etc. when it was in Miami.
But I know with aluminum it will take years if ever to do the same thing when they are an average of 3/8's thick.
Jon
KEPP
New Products and Member Discounts
4
03-06-2005 09:28 AM
