Hydro Lock
Old 10-28-2007, 06:58 AM
Xray50's Avatar
No water in the oil.....
Xray50 is offline
Old 10-28-2007, 08:21 AM
I would check again to see if there is any water in the oil .
The dip stick will show oil but at a higher level . The water is sitting at the bottom of the oil pan . I learned this when a gasket went on one of my engines . At first I thought the oil would turn milky . But it never was mixed up yet .
Good luck. Hopefully nothing got bent .
Paul
1bagger is offline
Old 10-28-2007, 08:41 AM
You and your girlfriend aren,t by chance shutting down the boat and drifting stern first to the waves while trying to conceive on the back hatch before all this is happening by any chance?.
tommymonza is online now
Old 10-28-2007, 09:18 AM
If this is true we will need pics to see if this is really your problem.
Edward R. Cozzi is offline
Old 10-28-2007, 02:31 PM
Xray50's Avatar
Intake gasket was all messed up. Will change gaskets and then drain oil. I drain from oil plug on the bottom of the pan. That should get most of the water, if there is any out. ?My kids are grown up but we still practice conception on the boat. On the deck tho, not on the rear hatch. Keeps the water out of the exhaust that way.....will get some pictures when in KW for the races....yeah, right!!!! My wife will go for that!!!!!!
Xray50 is offline
Old 10-28-2007, 06:50 PM
Must be an epidemic happening here. 406 SBC in my 1968 Firebird coupe. Water in the Royal Purple. No water in cylinders, just the lifter valley from a defective intake gasket.
Good excuse to pull heads and do valve job.
Old 10-28-2007, 06:52 PM
cuda's Avatar
Fill the crankcase with half cheap oil, and half diesel. Run it for about five minutes, then drain it. This will usually cut out any emulsified oil.
Good luck Ray.
cuda is offline
Old 10-28-2007, 06:58 PM
[QUOTE=cuda;2320294]Fill the crankcase with half cheap oil, and half diesel. Run it for about five minutes, then drain it. This will usually cut out any emulsified oil.
The oil cooler will need to be cleaned /blown out of any water/oil & then again for the diesel mix .
Good Luck
Old 10-28-2007, 08:13 PM
cuda's Avatar
[QUOTE=RUNNINHOTRACING158;2320305]
Good Luck
The diesel won't need to be rinsed out. Diesel has very good lubrication qualities. That's why fuel injection was widely used long before it became popular with gas engines. It should all drain out anyway.
cuda is offline
Old 10-28-2007, 09:00 PM
rchevelle71's Avatar
Let me know if ya want some help ray, I will be around all week after 4:30, gonna run next week???
rchevelle71 is offline
Quick Reply: Hydro Lock
