What temp. will freeze a 496HO not winterized?
John
Ginger or Mary Ann?
Other reason to keep the drives down is to keep the 2 bellows from devolping a hooked set. With the drive up, the bellows are curved. Just a little more harder on them to be stored in that position for extended periods of time then possibly failing once the drive is lowered. Or so they say. Not sure about the hyds, but with the drives down, no load on the cyl (granted not much there anyway) and the piston rods are not exposed to atmoshere. Retracted they are in submerged in trim oil. Plus the rods won't get a scale buildup if they were extended, then ruining the seal once retracted. Only reason I could come up with, but you see them stored up all the time.
US1 - You brought up a couple more reasons that I hadn't contemplated. The hydraulics being the reason never sat well with me, considering there is so much more pressure on them when running the boat. However, the bellows and exposure of the shafts to elements do make a bit of sense.
Thanks,
John
Thanks,
John
