msd timing curve
http://www.msdignition.com/tc_3.htm
Start retard--------total timing retard via chips for that time when premium fuel may not be available. Nice options.
I would use the black bushing and the light/silver springs,then set your total
http://www.msdignition.com/pdf/8360_frm%2023793.pdf
But all my stuff with MSD dist I just lock it out![Big Grin](/forums/images/smilies/biggrin.gif)
Also MSD is just starting to powder coat the inside of there dist so they want rust,it might take a while to hit the stores
again you come through strip , my engine builder had my msd set with the two large silver and the blue with 32 total i was thinking 598 na one silver small and one blue black bushing 34 total 10.1.to one dart pro ones just want to be safe and not give up too much locking it out been mentioned alot just not sure if that will work for me thanks again guys
The only prob I see with locking it out in a boat is detinating it getting it on plane or nailing it below 3000. Also with you at 10.o its a higher chance of det, but I asume you have alumiun heads? you have that chousion![Big Grin](/forums/images/smilies/biggrin.gif)
locking it out sure makes it crisp. kinda like krispie ,Rice crispi pops, Snap crackle &pop. Just stay away from the pop![Stick Out Tongue](/forums/images/smilies/tongue.gif)
yesme dinking![Stick Out Tongue](/forums/images/smilies/tongue.gif)
![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
yesme dinking
Run it locked..you will be fine. I have run every boat motor I've had locked with no problems and have many friends who have done the same..
I had a 10.5:1 632" motor with Dart 360's locked, it liked 32 degrees...A friend of mine with a nasty 598" motor had to put a curve back into his last season...why? well when he went to a tunnel ram with (2) dominators he couldn't get the idle down and would be too lean at idle as he droppied it in gear and it wanted to die...well, he put a curve in the motor and it solved the problem...that is the only motor I personally know of that benefitted from a curve...but it was to solve an idle problem from having huge carbs...
yesme dinking
