Estimated horsepower on rebuilt 454 mag??
A friend just rebuilt a 1997 Merc. 454 Mag and kept it completely stock except for the below changes. Can anyone estimate what the horsepower is?
1. Rebuilt at .030 over
2. Compression ratio 10:1
3. BG SeaDemon 750 CFM Carb
All else is stock.
Thanks.
All else is stock.
Thanks.
Don't you first need to know what the factory hp rating was on the motor or was there only 1 option that year, I know my boats older and there were 3 different hp ratings depending on the heads
There was only one "454 Mag" motor (with a carb) in 1997. The other motors were referred to the "7.4" and the "454 Mag MPI "(or possibly EFI instead of MPI). I believe the "454 Mag" was rated 350HP at the prop that year and the MPI variant at 385HP.
Should have changed the cam as well. That could bring another 30-50 hp.
