Time to rebuild 525's
Lostinboston, I feel for you, I just got my boat back in August after having to rebuild a 525 from a CMI header failure and the NEW header failed in 4 hours destroying another engine! CMI says they will NOT warranty anything. I am going to send a letter to the CEO of Brunswick. I suggest the same.
Dont just not buy a boat because of the headers thats on it
This is an interesting post because I have been looking at boats with 500efis and 525s. Dont both use the same header and what are some signs to look for to spot problems? Is it a certin cylinder. Thanks for the help.
Quinlan
Quinlan
Geronimo36
When I buy a car from GM, the exhaust system attached to the engine is warrantied with the car... If Merc. is truely doing this they need to spend more R&D on exhaust systems that LAST....
JB Marshall
What did you or are you going to do about the leaks you found. I have twin 500 efi's with 250 hrs on them and they run fine but this CMI leak thing makes me nervous.
Geronimo36
I have a welder that I have known for years, he specializes in marine systems. He can fix them most of the time. Very well known for his reputation in my area...
