how to winterize fresh water system
Try this. Buy 2-3 way valves and hook them to the in and out of the hot water heater. Run a bypass hose between the valves.
In the fall, just turn the valves to bypass the water heater. Open the drain on the water heater and leave it dry.
Been doing it that way for years.
Gary
Gary
Yes the hot water side is the problem. I need to pour about 8-10gals in my empty FW tank so I can fill the already drained and closed up 6 gal Hot water tank then the rest. When all fixtures run solid pink you know you are good. Flush a few bowls full of pink down the toilet as well. Done it for years, very easy and fairly cheap. I also put 2 gals in the just pumped out so nearly empty holding tank. Then flush it all out in the spring.
Gary
Gary
You should not run anti freeze through heater drain and by pass. I drain water tank and pump anti freeze through lines without adding to tank. Easier to flush pink out in spring.
Jim
Jim
Go Big or Go Home
I agree with jim drain your water tank pull the hose off the tank that feeds the pump and put that hose in a gallon of antifreeze run the system as normal till you see solid pink. if you have a hot water heater you must bypass it. A little water left in the bottom of the tank is fine it has plenty of room to expand.
Most of my friends and I just blow the system out with compressed air. I built a fitting to connect my compressor hose to my water intake. The process I use is this: run all of the water out of the tank, leave a faucet open, start the compressor, let air run until the faucet stopps spitting, open the next faucet, close the first faucet (do not leave the compressor running with all faucets closed - system can't handle the pressure), and so on. If your head works off of fresh water make sure to cycle the head a few times while under air pressure too. I usually take a 30 minute break to allow any remaining water vapor to settle and then repear the same. I've never had any problems (I am on Lake Erie - gets plenty cold enough to freeze!). This lets me just sanitize my water system in the spring (cup of bleach, fill and run water out 2-3 times) and off I go.
Hope this helps.
Hope this helps.
MacGyver
11-11-2008 12:51 PM
