Switching from efi to carb, which intake should I use?
Where To
Dart 6200 or Check out CP's sale!
Savings Like This Only Happen...
ONCE A YEAR!
HP 500 Style Carburetor/Intake Manifold Power Package
If you're looking to build an HP 500 style motor but are not sure of exactly which parts you may need, then this kit is for you. Nothing could be easier.
We have combined all the necessary items to produce an HP 500 style package in kit form. This kit includes:
(1) 620-53031 Hardin Marine Big Block Chevy Intake Manifold
(1) 710-9022 Holley Marine 800 CFM Carburetor
(1) 620-52001 Intake Allen Bolt Kit
(1) 620-53106 Carburetor Stud Kit
(1) 300-17342 Extreme Seal Intake Gasket Kit
(1) 620-04112 Water Outlet Gasket
By purchasing these items in kit form we are able to offer you a substantial savings! Don't wait, this offer will only be available for a limited time.
Click on the links below to check pricing or place your order.
Part No. Description
620-54000 HP500 Style Carb & Intake Manifold Kit, Plain Satin Finish Intake
Reg $789.99 Sale $729.99
620-54001 HP500 Style Carb & Intake Manifold Kit, Plain Satin Finish Intake
Reg $859.99.99 Sale $799.99
This offer expires December 31, 2007.
ONCE A YEAR!
i LEFT A POST ON GD if you want to go check it out I have had DART SINGLE PLANES one for 7yrs and one for 12yrs in saltwater only just flush it out, but check my post in gd
The heads are hard anodized in all the water passages, and exterior. Your right, I don't have to have brass inserts, but it would be one less thing for me to worry about. I guess I could have the intake hard anodized also.
My thought is , I have never heard of heads getting so corroded that they leak, but I've seen it happen on intakes alot.
Thanks,
Frank
Thanks,
Frank
Well that sells me on closed cooling! I guess it would be worth the extra few dollars.
I run in bracish water, but I get a good fresh water flush when I come home up the river.
Thanks,
Frank
Thanks,
Frank
Charter Member #40
Frank you will love closed cooling. A few yrs ago played with a 502 with several intakes/hydr. cam combos on a dyno and ended up with 620hp/592#' at 5500 with KE's exhaust. Ended up with a Brodix HVH intake and were using bolt on Canfield heads. Also had 9.5:1 compression. You should be able to do the same if not better. Good luck!
The block has triangular/oblong water passages. The AFR heads have round water passages which are smaller than the water passages on the block. The head gasket is built to allow the gen iv style heads to be bolted to a gen vi block. So the head gasket seals around the oblong passage because it is bigger than the hole in the head. This allows salt water to get between the head and the head gasket in the part of the gasket that did not seal and causes the corrosion. You can see the outline of the head gasket seal in the above picture.
Rambunctious
5
12-13-2007 09:35 PM
ls1nova
12-02-2007 05:11 PM
