Where should I splice into for Engine Hr meters? Thanks!
1 Post
Well for me the closest ground in the bilge where my hour meters are would be the block or the mercathode would either of these work? I really don't want to use the ground on the trim pumps. I'm hoping on the 500efi's there's a connector somewhere so I don't have to splice into the wire prefer not to cut the harness anywhere. I also read that on the alternator there's a positive post that only is hot when engine is running which would be ideal if so...Any truth to this?
Either will work fine to ground it. Use the purple to the coil.
1 Post
I'm either not doing something right here or there's more than one purple wire. Can you give me a idea where to look exactly for this purple wire cause the one I found doesn't have power with the key on.
