roller rockers?s
Registered User
what will the added h/p gain do to the ecm?will i have to re-program the unit?i was told that any change to the engine other than stock will result in the engine not running in tune,therfore the ecm will have to be reprogramed,is this true?baja bob,what brand of rocker did you break?thanks all for the input.
As others said, it will reduce valve train friction......
As said before, buy quality and not a no-name off of EBay.
Another thing to remember is the new motor oils have less and
less of the stuff that protects sliding surfaces. (The old oil additives hurt next gen cat convertors)
One of the major reasons the Gen VI has roller lifters and rockers.
There is literally no down side to full rollers. Better efficiency all around.
A higher lift rocker is something to really consider. More lift in the rocker is like spoofing a bigger cam, except more rocker lift is quicker than more cam lift.
As said before, they won't give you a ton more power. The engine actually runs the same way so no ECM change necessary. you pick up power from the lack of friction (assuming you stick with the same rocker size). if you bump to a bigger rocker size you may need a reprogram.
My fear is the stock valve springs that have about 150hours on them.
Do you think I should change the valve springs if I do want to install the 1.8 ratio rockers????
I don't think an ECU remap is necessary with the 1.8, but maybe a little more fuel pressure.
Patrick
Patrick
Registered User
We won't build or sell any marine motors without stainless or certain aluminum roller rockers. As said already here on this thread, they add about 10-15 HP on any big block (dyno proven), they keep the oil cooler, stabilize some valve train issues and are much more accurate in ratio than any stamped rocker.
Very good investment for the dollar. Just make sure you purchase quality units, like Comp, Crane, Crower, ETC.
Regards,
Ray @ Raylar
Regards,
Ray @ Raylar
zimm17
5
05-25-2007 09:24 PM
