molded hose
Old 01-25-2008, 11:21 AM
rv
Default molded hose
Is there a source for a molded rubber hose. I am looking for 1/2" ID rubber type hose with a formed 90 on one end and 55" of straight hose. Is there a location that can provide this type of hose without doing a 1000piece minimum order???
I checked the local auto parts store to see what maybe close but the typical hose is 5/8 or 3/4" in something similar.
Thanks,
Rick
rv is offline
Old 01-25-2008, 02:46 PM
Thanks,
Rick
You could get the 90* bend and use a splice for the length.
kennyo is offline
Old 01-25-2008, 03:15 PM
rv
Thanks for the idea but I would prefer a single piece. Any other suggestions for place to get this???
rv is offline
Old 01-25-2008, 09:11 PM
for 1/2 ID, why not use braided stainless hose, with a 90 end fitting? Can get a large radius 90 if you need it larger.
Joe92GT is offline
Old 01-25-2008, 09:23 PM
offthefront's Avatar
I have looked .... I dont think there is a source ... I have gone to Napa or local Auto store and they let me just go in the back and look thru hoses ... As said the 90* is easy but then 55" ? Bet that would be tough .... Like the braided SS hose Russell Makes a Black Braided hose that is real nice... $$$ though ...
Or go to your local Hydraulic Supplier and you can get 1/2" hose with brass or SS push on Fittings .... Summit or Jegs also ....good Luck .....m
offthefront is offline
Old 01-26-2008, 06:21 AM
rv
Thanks for the thoughts guys. The stainless hose/fittings would work for sure. It is a little high $$$ for the what it is needed for.
rv is offline
Old 01-26-2008, 09:52 AM
Smitty's Avatar
Rick,
Call Geib industries in Franklin Park. They are an Aeroquip dlr, but also sell other Aeroquip fittings for much less. I used all nickel and brass fittings with push lock hose to plumb my boat.
They will have whatever you need and sell any kind of hose you would ever need by the foot.
Smitty is offline
Old 01-26-2008, 02:01 PM
Originally Posted by Smitty
Rick,
Great suggestion. For the budget boater, try using the external spring hose forming accessory.
ROTAX454 is offline
Old 01-26-2008, 08:55 PM
johnny g's Avatar
If you found it in 5/8 or 3/4, why not bushing down or change the fittings to accomidate?
johnny g is offline
Old 01-28-2008, 02:56 PM
We Sell Silicone Heater Hose That Is 1/2 Dia.
This Hose Bends To Tight Radius And Does Not Colapse.
Jb-fse is offline
Quick Reply: molded hose
