Morel lifter?? >
Morel lifter??
Morel lifter??
Old 01-28-2008, 02:07 PM
The Morels are designed to be a direct replacement and use the OEM length for the hyd roller Gen 6 engines. Whether you use retro fits or drop ins the pushrod length will be the same.
cstraub is offline
Old 01-28-2008, 06:09 PM
Originally Posted by kennyo
Are Morel lifters a direct replacement (same height) as stock roller lifters on a 502 mag? I just spent a fortune on custom length pushrods and don't want to do it again.
Thanks Chris (CSTRAUB), Saves me from digging out my measuring tools. If the original statement is taken at face value, no change in the pushrod length is necessary. If you do wish to validate your choice in the custom length rods, the mock-up plan (as recommended by Jeff1000) is good. However, don't forget to use these when using the rod length checkers. Don't want to colapse the lifter beyond your lash value.
http://store.summitracing.com/egnsea...=KeywordSearch
ROTAX454 is offline
Old 01-29-2008, 09:02 AM
Thanks Chris, I'm familiar with all the above advice. Your quote is what I was referring to. Thanks for the responses.
kennyo is offline
Bryan Rose
1
06-14-2011 11:11 AM
alecsammy
8
08-07-2009 08:28 AM
Ken N
9
10-25-2008 11:35 AM
ak
Swap Shop
1
10-25-2008 09:29 AM
Bryan Rose
Prop Talk
3
08-24-2006 09:21 AM
Quick Reply: Morel lifter??
