GPS speedometer antenna options
here try this: http://pinouts.ru/CellularPhones-A-N...0_pinout.shtml
many of the older Nextels use the same serial data connectors....oh and be careful...i found out that some of the newer Moto phone have a different serial cable now...i know the i930 takes a special cable that has a toggle switch on it to switch from data to flashing now...dont know how that one would be configured to work on a setup like this
hope that helps ya
Just curious why you would want to hook it up to a hand held.
Originally I was going to hook the speedo to my gps because I did not want to mount the antenna, I found out that you don't have to mount the antenna externally so I just mounted it inside the dash. It works perfectly.
I hooked mine up to the handheld to save a few bucks by not buying an antenna. All I had to do was connect two wires form the handheld harness to the speedo harness. My handheld is mounted on the dash.
