can i cap off my exhaust bellow?
Chris
You can buy thick rubber plumbing sewer test caps at your local Home Depot that come complete with a hose clamp. These units are for pressure testing sewer lines, and are the exact correct size. Cost about 5 bucks a piece. Easy to do untill you are ready to pull your motor to install the block off plate.
Hope this helps,
Chris
Hope this helps,
Chris
if i wasnt in the middle of building another dyno trailer i MIGHT think about pulling the motor, but since there isnt any room at the shop now thats not happening!
CB- i though about that, and i will probably do that, but ill also have to remove the Y pipe diverters that are part of the thru hall and just put some straight pipe there, otherwise water will fill in correct?
im also wondering if just putting straight pipes in there will make it sound louder since i have a feeling its getting some muffling from also partly running through the prop still because of the diverters what do you guys think?
