Compression ratio difference w/ aluminum Heads??? >
Old 02-16-2008, 07:56 AM
If you're running in salt water, you're better off with cast-iron heads. I've pulled many aluminum heads that were junk after a few years.
Edward R. Cozzi is offline
Old 02-16-2008, 08:37 AM
PatriYacht's Avatar
I have heard that aluminum heads, all things being equal, lose a few hp because of higher heat conductivity. They usually flow better and that's why they make more power. I think alum. is better in fresh water because they're lighter but in salt they corrode to fast.
PatriYacht is offline
Old 02-16-2008, 02:14 PM
The water jackets can be anodised to protect the aluminum. Remember, most every high performance intake, along with intercoolers are aluminum. Plus every jet ski motor made, and all outboards. Don't worry about aluminum in the motor. Just flush with salt away when finished.
Darrell.
DMOORE is offline
Old 02-21-2008, 02:25 PM
Rage's Avatar
I was only speaking to the impact to motor performance of aluminum metal versus cast iron metal as a head material. In other words the exact same heads except one made form aluminum and the other cast iron.
Originally Posted by Edward R. Cozzi
I doubt that's true as a rule because most aftermarket aluminum heads flow better than the stock cast-iron heads, are therefore more efficient and make more power. I learned this straight from Randy Garciga from Cobra Power, so it is not something I'm making up.
Rage is offline
Old 02-21-2008, 05:17 PM
Rage,
I doubt you are going to find many/any on OSO that have made two idenitical sets of heads (except for the metal type ) and then done back to back dyno testing/comparisons. as the engine is an air pump, it doesn't care what metal is used in the heads. The power should be close to the dsame if all else was equal. Aluminim is lighter (faster) and cast iron is more corosion resistant. Power? ...same.
BenPerfected is offline
Old 02-22-2008, 02:21 PM
Revelocity's Avatar
Here's a related question that if I had a Desk Top Dyno program - I woudn't have to ask. Given that aluminum heads can tolerate a higher compression ratio for a given fuel grade, is there any rule of thumb that says if one increases the compresion ratio from say 8.75:1 to 9.75:1 (an 11% increase) and ALL ELSE REMAINS THE SAME, that horsepower will increase x %? I'm sure the relationship tails off with higher compression ratios but for THIS range can anyone offer an estimate of % HP increase? I'm trying to figure what higher compression potentially delivers in extra horsepower. Thanks.
Revelocity is offline
Old 03-03-2008, 11:38 AM
Rage's Avatar
Oh yes it does. You are missing the point. The higher the combustion temperature the more power, the lower the combustion temperature the lower the power on a given engine. This is where the better thermal condutivity of aluminum versus cast iron can reduce power. Conversely that same characteristic can reduce potential of detonation thus allowing aluminum heads to be designed with higher effective compression ratios which can gain back power. I have no idea if it is a wash or if the increased compression ratio capability produces more power gain than is lost to quenching of combustion temperature or the opposite.
There is no limit of things to take into account in head design differences and material choices. The comment above was intended to discuss only one, aluminum versus cast iron and its effect on power all things being equal.
Originally Posted by BenPerfected
Rage,
Rage is offline
jackhammer
14
06-12-2007 08:24 AM
1BIGJIM
15
03-16-2006 12:33 PM
danielthelen
5
05-09-2005 02:44 PM
HARRISONMIRAGE
1
12-13-2003 07:17 PM
WETTE VETTE
12
05-31-2003 06:44 AM
Quick Reply: Compression ratio difference w/ aluminum Heads???
