What size BTU Marine Air Conditioner?
FIERCE ALLEGIANCE
At the Miami show the AC guys told me a 5000BTU would be perfect for a 99 top gun cabin? They said if I go too big the unit won't dehumidify and I'll get moister build up?? Thoughts? I was looking for a 10-12M system but everyone in Miami told me the same thing regarding a 5000BTU system? Also, is a reverse system (heat) worth it? I don't think we'll use it that much in the fall but might if we knew we had heat?
Ginger or Mary Ann?
Both myself and a buddy installed 6500k units last winter. a 32 Fountain and a 35 Cig Cafe. Neither one of us has any problems, granted I don't have the cabin space as you. Also state may come into play. We opted for the R/C since it was only a $50 upgrade. Well worth it IMO. We start boating mid May and go till Nov 1.
Also been told not to go too big as the unit will cycle on/off to much, not removing the humidity. The state you'll use it may also dictate if you need to step up in size.
Last edited by US1 Fountain; 02-24-2008 at 08:52 PM. Reason: wrong btu size initially posted
21 and 42 footers
I'd go with a 7,000. It's what I have in the Formula, it's worked well whenever we've needed it, and the Honda 2,000 will run it. James and some of the others with the 10,000 have had to add some extra hardware (hard start kit) and it max's out the Honda.
FIERCE ALLEGIANCE
You have to cut a vent in the glass just below the v-berth...to give it some air to breath...not sure where I'll run the vents yet, however you can get under the bed (v-berth) really easy. It's just a sail like material tied together and velcroed. I think I can use my existing exit line from either my drains or my head. If not, I'll drill another port. We're planning on a couple florida runs this year and need to get it cooled down.
Ginger or Mary Ann?
Don't see those deals often!
We run off shorepower, but the 6500 will run off a 1000w Honda generator, according to the Mermaid manual.
