Hydraulic steering or counter rotation? >
Old 03-05-2008, 11:36 AM
yikes's Avatar
I changed to a counter rotation Alpha 1 and it made a huge difference. The on and off throttle twitch disapeared. Much more relaxing to drive. My next step is to build a set of stroker small blocks.
yikes is offline
Old 03-05-2008, 05:42 PM
spazboz's Avatar
I'm going to switch my Nova II over to a counter-rotation drive this spring also. Would you guys suggest turning out, or in?
spazboz is offline
Old 03-05-2008, 05:56 PM
question about hydraulic steering, i have internal hydraulic steering, i guess the tie rod deal, but a lot of people have these rams on the outside, what is the diffrence/ benefits?
jlaudio29 is offline
Old 03-06-2008, 05:32 AM
yikes's Avatar
I run my CR lower on the starboard side. It gives a little more stern lift and is easier to control around the docks. Remember that you have to reverse your shifter when you put on the CR lower.
There are three types of steering.
Cable internal hydraulic uses a rack and cable from the helm to a stern hydraulic cylinder inside by the gimble.
Cable external hydraulic uses the same helm cable to activate the one or two external hydraulic cylinders.
And full hydraulic uses a hydraulic helm back to the external cylinders.
If your going 70 plus you should consider external hydraulic for safety reasons. I'm trying to work it into my budget when I repower.
yikes is offline
Old 03-07-2008, 02:45 PM
out usualy handles better, in might get you 1-2 mph . you just have to experiment
scarabfun is offline
Old 03-07-2008, 04:52 PM
the only way to know which way you will like the props turning is to try both ways. you have to switch the drives (or at least the lowers) to change rotation. try all your props turning in and write everything down. then try all your props out and write everything down. then make your decision on how you want to leave it. alot of work, but can be worth it
JIMG is offline
Old 03-07-2008, 05:13 PM
The only thing bothering me about the original post is two right-hand rotation propellers should make the boat heel to the LEFT. Something else is wrong here.
Edward R. Cozzi is offline
Old 03-07-2008, 05:44 PM
It would heel left and pull right.
MOBILEMERCMAN is offline
Old 03-08-2008, 10:28 AM
spazboz's Avatar
Thats what mine does with two RH drives. It heels left, the only real time I feel the pull is exiting waves on Lake Michigan. Other wise on flat water. I can let go of the wheel and it stays the course. But as I add more horsepower to the boat, I can tell this is going to be more and more of a problem. SO it time to reverse my thinking (get it) O,h.... that joke was SO BADD!!!!!!!
spazboz is offline
Old 03-09-2008, 08:26 AM
Note: You only reverse the shifters if you are running bravos. The shifters are not reversed for alpha counter rotating drives.
I have a question that was brought here on the thread. I have the alpha's turning in and the boat always leans to the starboard side. If I turned both drives out, would that correct my lean?
JimmyBaja is offline
Quick Reply: Hydraulic steering or counter rotation?
